I have a bunch of Star Trek tv shows I've recorded in avi that I would like to get onto dvd.
My question, what is a good method for converting these and getting the best quality and still get multiple programs onto one dvd disc? Most of the shows are around 300-360 megs each.
It's been a while since I've done this and use to use tmpgenc to encode and then DVDLab to burn the dvd's with, but I had some mixed results. Some dvd's would freeze up or skip...etc.
Looking for suggestions...maybe there is nothing better/newer than what I use to do.
Thanks for any suggestions!
Darkcyber
They are probably still the best tools for the job. At 300-360mbs each, I am assuming DivX/Xvid. What res ? If they are lower res, I'd suggest using half-D1. You should get 4 - 6 episodes per disk without sacrificing much if anything of the quality you have now.
Freezing and skipping usually means bad media. Try some better/different disks.
"Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by ZippyP.
I know this question has probably really been run over many times, but what are some of the better media to avoid these problems?
Thanks!
DarkCyber
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
burn multiple video files on 1 dvd using ConvertXtoDVD
By sascha_ in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2010, 06:09 -
How to convert multiple avi's to DVD with chapter points between each?
By Pierre1 in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2009, 07:38 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28 -
Convert multiple image files into one and burn onto DVD
By Mark97213 in forum Authoring (DVD)Replies: 1Last Post: 30th Jul 2007, 03:26
