The following is the way I back DVDs to 4.7 DVD discs:
1) Rip the DVD using DVDDecryptor, you can also rip using DVDShrink,but I had trouble with it for a couple of DVDs so I just use DVDDecryptor.
DVDDecryptor
Tutorial for DVDDecryptor
2) I then use TitleSetBlanker to blank out the Extras, FBI warnings, Trailers, etc, this will then enable you shrink the dvd with an improved video quality for the movie while maintaining the DVD Menus. There are other tools to do this but I found TitleSetBlanker to be the most easiest to use. You will also need DVDShrink 2.3 which allows you to see the RAW files so that you can determine which title files to blank out.
Title Set Blanker
DVDShrink 2.3 - use to see RAW title files
3) Use DVDShrink 3.1.7 to shrink the DVD that you ripped
DVDShrink 3.1.7 + Guide
4) Burn the shrunk DVD to Disc. You can output the shrunk files in DVDShrink to an ISO and then use DVDDecryptor to burn the ISO
Official DVDShrink Website
All this is done using great software i mentioned all for free, you can get the software from the links provided.
Results 61 to 63 of 63
I guess I'll be the first one to throw my vote to Intervideo DVD Copy. If I'm pressed for time and want to do just a movie-only backup I'll usually use DVD2ONE. But if I'm doing a full disc backup I now always use Intervideo. While I won't go as far as the recent test to say that it looks nearly identical to the original, I do have to say that it is the best program for full disc backups. Yes there is some pixelization, especially in darker scenes but you're going to get that with most programs. But some are better than others and I personally think Intervideo stands above the rest. I know I'm going to get crucified for my opinion here, but it is just that- my opinion. Here is a list of programs I have used in the past in rank order from best to worst (when doing full disc backups).
1. Intervideo DVD Copy 2 Platinum
2. Clone DVD
3. DVD Shrink
4. DVD X Copy Xpress
5. Nero Recode
6. DVD2ONE -
gitreel & ghoster: Thanks for your help. lol I realize that now
I am just going to stick with shrink. Once I see how the movie quality looks like, i will see what else i could do.
Quality loss in all programs except for VLC
By Dozza in forum Software PlayingReplies: 3Last Post: 21st Jun 2011, 10:33 -
Dvd programs for windows 7
By tansdad in forum Newbie / General discussionsReplies: 1Last Post: 14th Feb 2010, 16:39 -
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 16:51 -
Programs to Produce Very High Quality FLV Output Files
By devilcoelhodog in forum Video ConversionReplies: 2Last Post: 25th May 2009, 00:10 -
Good Programs that can rip lower quality dics?
By Super Warrior in forum DVD RippingReplies: 13Last Post: 14th Aug 2007, 19:14
