Results 1 to 16 of 16
    Aug 2003
    Canada
    there was 3 files to this movie, they are in SVCD mode
    the first 2 cd worked fine but when i loaded the 3rd file
    and it said it's
    -not a 11172-2 or 13818-2 Video stream
    -please go to tools and try fix stream headers on the file.
    how do i get dvd lab to load the file and i tried the fix stream header how do i use it i just loaded the file and clicked fix headers, and right away it says Nothing was fixed..
    help.. i need to add this SVCD file to compile ASAP!!!
    Aug 2003
    Canada
    helppppp
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Do you have a gun to your head ?
    Do you only have 3 hours to live and must watch this from a DVD before you pop off this mortal coil ?
    Just curious about the urgency . . .
  4. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    Does that answer your question?
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
  5. Originally Posted by The village idiot
    hehe...
    Have you tired running the mpeg file through a checker, or tried demuxing then re-muxing it? I bet this is some downloaded file that is screwed up. Never trust it unless you make it yourself.
    "A beginning is the time for taking the most delicate care that the balances are correct."
    - Frank Herbert, Dune
    Aug 2003
    Canada
    no i promised someone i would give a copy to her
    how do i demux it?? with dvd lab it tried to demux and cancelled becuz of that error
    hehe...
  7. Run the mpeg through VCDGear and "Fix Mpeg".
    Try again.
    Cheers, Jim
    My DVDLab Guides
    Aug 2003
    Canada
    Try again.
    i tried that already too it showed the same error
  9. Originally Posted by Solarjetman
    Originally Posted by RevMyOh
    how do i demux it??
    TmpGenc. File->Mpeg tools, simple de-multiplex option. That should do it.
  10. Un urgency 'bump' after only 38 minutes. That must be some kind of record.
  11. I love how descriptive the title is too.
    Montreal, Canada
    [quote="RevMyOh"]no i promised someone i would give a copy to her
    Looks like you'll have to take a cold shower instead.
  13. You could run it through Womble MPEG Video Wizard. It will not re-encode it. There is a free trial version you could use on the website.
    Aug 2003
    Canada
    TmpGenc. File->Mpeg tools, simple de-multiplex option. That should do it.[/quote]
    i tried doing that, but for some reason it only made 25 minutes of the 55 minute movie...
    does that mean there's an error during that 25th minute or something cuz it looks the same when i watched it
  15. Originally Posted by RevMyOh
    does that mean there's an error during that 25th minute or something cuz it looks the same when i watched it[/quote]
    It would appear so. Have you tried mwkurt's suggestion.
    Aug 2003
    Canada
    sweet that's the only way that worked.... thx!
