I am using adobe 6.0 - I knoe that's my problem right there..but it has worked marvelously for me...Not one problem until now.....exporting!
I am using a Sony DV Mini cam to impot and exoprt...but the export to tape just renders for like hours and tehn when it is finally time to export, its black - no pic.
When I export movie - it renders but only produces a clip length of 18:52 - nothing longer.
ANY SUGGESTIONS OTHER THAN SWITCHING PROGRAMS? I need good quality video export!
PLEASE!
The 18:52 bit sounds suspiciously like something to do with the 4 Gig file size limit. Are you using 98 or Me?
Al -
no I am using XP - you are 100% right the fil size is just under 4G...can this be changed??
In order to kiss the 4 Gig limit goodbye, you'll have to convert your hard drive or at least some of its partitions if you have more than one, to NTFS.
By the way, its well worth it.
Al
Adobe Premiere export same as original file?
By kray in forum Newbie / General discussionsReplies: 13Last Post: 9th Sep 2012, 00:05 -
is there anyway to export from Adobe After Effects CS5 to H.264? or other?
By Onceler2 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2011, 15:59 -
Best export settings in Adobe Premiere CS4
By Polesch in forum Newbie / General discussionsReplies: 5Last Post: 5th Apr 2010, 17:45 -
Adobe Premiere Pro: I used DV footage and Photoshop stills - how to export?
By neckneck in forum EditingReplies: 12Last Post: 20th Dec 2009, 15:29 -
FLV Import/Export Nellymoser audio - Adobe Premiere CS4
By shagen in forum Newbie / General discussionsReplies: 4Last Post: 19th Nov 2008, 17:38
