  1. Ok heres my problem..ive got a DVD that needs copyin (PS2 game) i have my pioneer A06 which always does the job for me but ive never copied a game to a DVD-R and im not sure i can because my other drive is not a DVD-ROM drive so im thinking it cant read it
    what program can i use to extract an image and then burn to DVD-r?
    also one of the games is very large and as im not running Windows XP it might not be able to handle the file unless it is extracted small so im thinking i might need a high quality extractor
    this is kinda urgent but i know everyone here is here to help..thanks
    Monroe, Mi
    just use dvd decrypter and write iso mode i believe
  3. sitlet is right, dvd decrypter is good for making images of ps2 dvd games.. but you said you're not using XP.. so you might not be able to make the image.. if the image is larger than 4GB (fat32 limit), i would suggest using recordnow max, it will span them over a few files, and then you can burn it with recordnow max..
