I have two questions.
In your guide it says:
"If you prefer to keep the source AC3 track, select AC3 (in that case, the source AC3 will be copied 'as is' without any re-encoding, so make sure to set 448 as audio bitrate when using the bitrate calculator)."
1.So it just takes the AC3 and uses it without touching it at all?
2. If the AC3 track that is currently there is 224 or 192 kbps would switching the setting for this on the audio tab give a better estimation on overall bitrate for the video?
video_TS to DivX
By kizandtango in forum Video ConversionReplies: 1Last Post: 25th Apr 2008, 21:37 -
VIDEO_TS to DivX w/ ffmpegx
By motherwell in forum MacReplies: 2Last Post: 7th Apr 2008, 15:10 -
VIDEO_TS to DivX Ultra
By spidey in forum Video ConversionReplies: 14Last Post: 26th Mar 2008, 03:05 -
Problems creating VIDEO_TS -> DivX
By Someguyyyyyy in forum ffmpegX general discussionReplies: 3Last Post: 6th Feb 2008, 15:09 -
ffmpegX 0.0.9 Video_TS to DivX
By stcowboy in forum ffmpegX general discussionReplies: 10Last Post: 29th Dec 2007, 02:11
