Where can i find the file that gives me the abbility to export from quicktime to Toast Video CD format? i need it..
thanks!
Results 1 to 9 of 9
In Toast 6.x, the QT export plugin is gone. You now just drag your QT movies onto Toast's main window when in Video/Video CD mode.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
ok, .. but if i still want the export feature back
.. how do i do that? -
You don't. I mean, you could locate the export plugin for Toast 5.x and install that, but it's much lower quality and slower than the new one. Stick with the encoder built into Toast 6.x.
ok, lets say i have a imovie project, and i want it in a MPG1-file on my HD, not on a video CD in DAT. can i do that tith toast?
You can use ffmpegX or something... It will be faster and better quality than the Toast 5 mpg encoder. You can just choose to export to QuickTime/Expert Settings.../Movie, self-contained from iMovie.
MMT-EZ might be what you're after too. I think its main purpose is iMovie -> SVCD but it will do VCD and other formats too. It's much simpler than ffmpegx.
Try Divillusion =
http://www.versiontracker.com/dyn/moreinfo/macosx/22656
It makes ready to burn VCDs.
Export Video Header
By BRotondi in forum Newbie / General discussionsReplies: 3Last Post: 18th Jan 2011, 15:35 -
Blurry video on export
By beckerss19 in forum Video ConversionReplies: 25Last Post: 1st Oct 2010, 13:58 -
noob-help! plzzz! video-ts folder files export to something i can use...
By shedev in forum Newbie / General discussionsReplies: 4Last Post: 24th Mar 2010, 13:27 -
Crop video on premiere cs4 and export as flv
By v1p0n3 in forum EditingReplies: 2Last Post: 27th May 2009, 14:07 -
Did toast 9 do away with audio export?
By stanislawski in forum MacReplies: 2Last Post: 1st May 2008, 02:36
