I have tried just about everything I can think of and can not get audio with a motion menu. I can do it in DVDlab but want to do it in Author. I have authored a bunch of various DVD's and have never gotten audio in the menu. I have tried converting it to AC3, used mpeg1 layer 2, and PCM (wav). I am on a dual AMD 1800mp tyan running WIN 2000 pro. Any ideas?
thanks, glenn
I have also had the same problem.... some kind soul, please help us!
Have you checked this box
It looks like you have to have a background video to have menu sound -
Your menu background video must have muxed audio. Elementary streams (separate video/audio) will not work.
Muxing your video and audio clips should solve your problem. -
I am not getting any sound when i play the videos in tmpegauthor since i updated the sb live drivers. I think the sound is there when i have finished burning and playing on the dvd player. Its only when i actually author the videos that i cant hear the sound.
Creative is pain in the a$$
To the reply that told me to use muxed video/audio... I want to say thank you! I have not tried it yet, but I am sure that is the answer. I always use elementary streams because it seems to be faster that way overall. I use DVD-lab only once in a while, and am hoping that future upgrades give some pro features. Author seems to give me what I need... stability!
Thanks again. I'll try it tonight.
Glenn Woiler -
I just make my motion menus with sound and video in the same MPEG-2 file instead of demuxing it.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
In GUI Dvd Author-my finished dvd has no sound on the menu in some players?
By extent in forum Authoring (DVD)Replies: 3Last Post: 2nd May 2009, 04:19 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 03:56 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
TMPGEnc Author Version 2.0 - Unable to make a DVD with a motion Menu
By tug_hill2 in forum Authoring (DVD)Replies: 5Last Post: 28th Sep 2007, 00:37
