Do you need a fast computer to play DivX videos with AC3 audio? It's a game trailer that I got a while back. I tried playing it in Winamp and DivX Player, but neither would play it. I tried playing it in WindowsMediaPlayer, and it sort of worked. It looked like the audio wasn't synced. I have the codecs from the DivX Player installed and Nimo's Codecs installed. I uninstalled Nimo and used GSpot to tell me if I had the codecs needed to play the trailer, but I didn't. It told me I needed a Dolby Laboratory AC3 codec. With Nimo's Codecs installed it says I have 3 compatible audio codecs but they obviously aren't working right :\.
The audio plugin that is used (according to GSpot) is:
(S) --> AVI Splitter --> AC3Filter --> TFM Audio Filter --> Morgan Stream Switcher --> TFM Audio Filter 0009 --> (R)
Just get virtualdubMod and convert the ac3 to mp3 and select Direct Stream Copy for the video. That should solve it....
I completely forgot about this post. I think my problem was that using NVIDIA Settings I forced all programs to Antialiasing filtering to 4x and Anisotropic filtering to 2x. That's not a very good idea on a Geforce 2 MX
replace ac3 2ch with ac3 5.1 ch in mkv (and sync)
By umbbra in forum AudioReplies: 1Last Post: 12th Jun 2010, 05:18 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 08:06
