I was wondering, I want to encode a file into xvid, using 2 pass, and do different bit rate to check out the image quality differences.
Can I do the 1st pass once, and just use it to run the 2nd pass multiple times, changing just the target bitrate? What kind of information is recorded in the 1st pass anyway?
Thanks.
As long as you still have the video.pass file you can run as many second passes as you want.
Virtual Dub 1st & 2nd Pass Encoding
By OrchestraAndChoir in forum Video ConversionReplies: 10Last Post: 22nd Jul 2012, 07:20 -
x264, point of 1st Pass encoding?
By Sephisto in forum Video ConversionReplies: 50Last Post: 18th Apr 2012, 01:13 -
VirtualDub + Xvid: problem with file size in 2 pass encoding.
By marcinkk in forum Video ConversionReplies: 3Last Post: 8th Dec 2011, 15:47 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 06:59 -
Removing subtitles, running 1st pass again?
By moviebuff2 in forum Newbie / General discussionsReplies: 1Last Post: 28th Dec 2007, 06:20
