I want to create 1 mpg movie out of 2 .VOB files. (when I ripped the DVD, the begining of the movie was the first .vob and the rest was the 2nd, and I don't want to make a seperate mpg for each) Note that I can't re-rip the DVD. How do I do that with TMPGENC. Is it possible?
This is what I want:
1st.VOB + 2nd.VOB = one mpg movie
and the program I want to use is TMPGENC.
Actually, my real question is: Can I open two movie files at once in TMPGENC to create 1 mpg out of those 2 movies?
Results 1 to 9 of 9
Originally Posted by sacred ff
well the thing is, I want to make an SVCD with that mpg. I don't know how I can "fuse" two movies so that they are one mpg. TMPGEnc is the best program I've tried for encoding avis to mpg. So I'd prefer if I can do that with TMPGEnc. I can make an AVI with those .VOBs, but it will just take too much time and will cause a loss of quality. So I want to make the SVCD-ready mpeg in one shot using TMPGEnc, but the problem is that the movie is seperated in 2 vob files, so I want to make a
SVCD-ready MPG from 2 vob files using TMPGEnc. Is it possible?
(And in case I want to use the program you told me to, Capmaster,
does Womble have these features: Resize and sharpen edge? I use those to make sure I don't lose the sides of the movie because the TV clips off the sides and I like sharpening the movies to make them the clearest possible. And is the quality of Womble as good as TMPGenc and is it faster/slower? I don't know anything about this program so...... is it made to create (s)vcds?) -
Originally Posted by BJ_M
I'm sorry if my questions are stupid, I'm a newb and don't know (really) anything about encoding (I just use TMPGEnc and Virtual Nan/Dub)
thx for your help in advance -
you can even frame serve two tmpgenc projects with vfapi.exe and send both to a new session of tmpgenc and join two vobs that way ...
see guides to the left on frame serving- its very easy to do .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Could you please explain step by step what I have to do?
I'm gonna try it now, but just in case I do something wrong, can you please? Thx in advance. -
we need to make a guide on frame serving with tmpgenc , seems there isnt one in the guides section ...
you basicly load your video into tmpgenc and save as a project , and load that project fileinto vfapi.exe and make a fake avi --
make all fake avi in same directorys and name like this:
avi.001.avi
avi.002.avi
avi.003.avi
then load your first (avi.001.avi) fake av into another session of tmpgenc - tmpgenc will open all 3 avi and make mpeg merging them as one ..
also you could use dvd2svcd instead..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
You can also open the vob's with Virtualdub-mpeg2, append them together, then frameserve directly to TMPGEnc.
Here's a frameserving guide.
The advantage of frameserving is that you don't need to save to an intermediate file and you don't convert the file into another format unnecessarily (which causes quality loss).
Seems to me that DVD2AVI could be used to frameserve your vob's as well."Art is making something out of nothing and selling it." - Frank Zappa
getting MediaCoder to copy audio during mkv to mpg encode?
By MilesAhead in forum Video ConversionReplies: 0Last Post: 15th Dec 2010, 02:47 -
Should I encode my movies to DVD?
By rocky12 in forum Newbie / General discussionsReplies: 2Last Post: 21st Mar 2010, 01:00 -
Re-encode files to make them smaller.
By Benhermies in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2008, 19:27 -
Best program to re-encode XviD files to make them smaller?
By Benhermies in forum Newbie / General discussionsReplies: 1Last Post: 24th Apr 2008, 22:32 -
any way to make changes and not to encode entire slide show
By tryintoo in forum Authoring (DVD)Replies: 0Last Post: 9th May 2007, 17:02
