  1. Hi,
    Today I tried dvdrebuilder for the first time with (LOTR 3 - TROTK, PAL version).
    If I select the source path I only see VTS_3 and not VTS_1 and VTS_2.
    Am I doing something wrong???
    Oct 2002
    south wales
    I suspect this is an easy one.
    I received the region 3 return of the king 8 days before worldwide release (as no doubt others did).
    I proceeded to rip it.
    You probably have not ripped it correctly.
    Use dvddecryptor to rip the full disk. File mode is better.
    It is not as big as i thought only apx 7½ Gb.
    It should work fine then.
  3. Banned
    Dec 2002
    Originally Posted by maupie
    Hi,
    actually it is even easier than that...
    DVD-RB only shows the VTS sets that will be processed...
    the others that aren't in the list are small enough not to be touched
  4. Is it really this easy.
    Thanks, I didn't know that,
  5. Member archaeo's Avatar
    Mar 2004
    mountains
    you might want to see this post...
    http://forum.doom9.org/showthread.php?s=&threadid=76940
  6. Banned
    Dec 2002
    Originally Posted by archaeo
    how does that post relate to his question about VTS?
  7. Member archaeo's Avatar
    Mar 2004
    mountains
    you're right, sorry my mistake.
