Using tmpgenc 1.5.20.62 trial. I just got a Panasonic dmr50 using it to convert old VHS tapes to DVD. I can play all clips in the Panasonic. On some clips when trying to convert to DVD using TMPGENC Video Wizard to add video clips I get "the program is a mix of different video formats" error. The clips are from the same tape. I have this problem with only some of clips others are fine, with the good ones I can create a DVDR.
Any Ideas?
Thanks.
Win98SE
try re-recording the troublesome clips, and make sure you use identical settings, i.e. you can't do half on SP and half on EP
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 20:08 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 22:44 -
TMPGEnc 3 error 0.80070005
By impmon2 in forum Video ConversionReplies: 6Last Post: 18th Jul 2008, 22:00 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28 -
TMPGEnc Plus Error!
By redtrigger in forum Video ConversionReplies: 15Last Post: 9th Jul 2007, 12:05
