I have 2 dvds i have created from mpeg's without menus and would like to put both on one disc. i have done this using dvdshrink's re-author mode but would like to have a menu so i can select which film i want rather than having to skip through the first to get to the second.
I dont have the mpeg's anymore so cant create the disc from scratch.
Thanks for any help.
Dave.
Cheers, Jim
My DVDLab Guides -
yes your right i forgot about that, thanks very much but is there a way i can do it without having to re-rip them?
Dave. -
no, just take the disc and say abracadrabba, and they will magically be changed how you want them on your burnt dvd
member since 1843 -
real easy way using tmpgenc dvd author.
you can add titles (title = dvd and tracks = chapters)
you and add dvd files (vob) and you search for the videots folder.
it will read the info in the folder and give you the option of which stream you want (which vob series you want)
if you want them all, add them either as titles or tracks.
since you want 2 movies each movie is a different title, if you want the extras, put them in the as tracks under whatever move they are from -
For more versatility, let DVDLab reauthor. It can also read .vob files.
Cheers, Jim
My DVDLab Guides
Films onto disc
By Pumkinhead in forum Newbie / General discussionsReplies: 3Last Post: 19th Aug 2010, 06:00 -
Bdmv Films - Disc
By Teac23 in forum Authoring (Blu-ray)Replies: 2Last Post: 22nd Feb 2010, 09:02 -
DivX DVD Disc with Menu
By MI6 in forum Authoring (DVD)Replies: 3Last Post: 6th Jan 2009, 11:07 -
Help: Freeware for basic DVD menu from VIDEO_TS/VOB
By pannayar in forum Authoring (DVD)Replies: 11Last Post: 12th Aug 2008, 04:17 -
Help to finish a basic DVD project with menu, chapters and videos?
By mikeli in forum Authoring (DVD)Replies: 4Last Post: 29th May 2007, 12:11
