I have an NTSC DVD player but PAL (S)VCDs are compatible. PAL's resolution is higher, so I'm guessing that when I play them, the quality will be better as well, am I right?
I'm the kind of guy who doesn't care how many CDs are spent, as long as the quality is DVD-most. So what do you suggest, I use PAL or NTSC? Will the image be stretched if I play PAL on my NTSC DVD player or will the player adjust it to be original resolution?
If you're talking about purchasing DVD/SVCDs, pick PAL if available.
If you're talking about converting to DVD/SVCD, use NTSC if the source is NTSC. PAL if the source is PAL. -
PAL has higher resolution at the expense of framerate. It'll be less smooth in high action scenes. Neither is better - just different.
PAL is vastly superior to NTSC, but you will see no benefit if the original source is NTSC. If you are able to record on a PAL camcorder and then convert to a PAL DVD, you will have much better pictures (resolution / colour) than a similar NTSC recording.
Thx. My source is NTSC. What I usually encode is anime (always NTSC).Originally Posted by pyrohydra
And I forgot that PAL's framerate was bad, so in other words, if I had remembered that when posting this topic, I would have cancelled!
Thanks to all of you who helped.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
