Just out of curiousity... how does one tell what the media code/Company Procduction is of a particular DVDR? (without using PC Software...)
Eg, How do you tell if a TDK 4x DVD+R 4.7Gb a RICOHJPNR01? and not something like the CMC... etc..????
interesting now that i think about it...
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick
If you are in the UK and buy from a reputable supplier (such as www.blankdiscshop.co.uk) they quote the media codes in all their listings. You know exactly what you are going to get then.
READ the sticky right above about this very same question - it will tell you all that you need to know about how to check the dvdr media. I'm not sure why you don't want to use pc software to do so, because that's the easiest and most reliable way to do it (and it's free). Just read above and it should all make sense.
He wants to know what media code he is buying, not find out after he already bought a spindle.Originally Posted by nickelzy
I think the only good way is to contact the vendor beforehand and ask. If they say they don't know, don't buy from them. If they say it is X, then you have it in writing if they send you Y. Other than that, try to buy sample packs. I think they contain the same DVDRs as large spindles. That is a cheap way to find out a lot of media codes from a vendor. Once you do that, post you media code results.
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 13:20 -
Looking at buying Bluray media..(some questions)
By SE14man in forum Newbie / General discussionsReplies: 15Last Post: 21st Feb 2010, 20:31 -
Help Buying Digital Media Player
By Gerrich in forum Media Center PC / MediaCentersReplies: 0Last Post: 5th May 2009, 22:03 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 17:58 -
OfficeMax / OfficeMax.com warning (blank media buying)
By lordsmurf in forum MediaReplies: 10Last Post: 15th Nov 2007, 05:51
