hi,
i converted a vob file into dv in order to import that in imovie!
i realized that the dv file was huge and that i could't import that in imovie!!
what should i do???? is there an applicaiton that i can separate the dv file into different tracks with less Megabyte in order to able to import that in the imovie??
thx
You sure iMovie can't import it? Is it .mov or .dv? You could always break it up into <9min28sec19/30frames segments with QT PRo, importing into iMovie, and putting them back together.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
i already said that i converted that into dv!!!!!
u cant import into i movie huge files of dv (like or 5 giga or something like that).
how can i do that in quick time??
i need something that can split it in 1 giga per track -
Have you tried Avid Free DV?
If you'll spend money Final Cut will do this as well. -
iMovie has 2Gb file limit...Check this site:
http://danslagle.dvmix.com/mac/iMovie/
There You can find script which will split Your DV movies to 2Gb automaticaly... -
In QT, just select chunks <9min28sec and cut and paste them into their own movie files, and save as self-contained. Then you can import the chunks into iMovie.
How to auto divide DVD into editable clips?
By yamahaalex37 in forum Video ConversionReplies: 5Last Post: 18th Jan 2011, 01:59 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 02:56 -
how can you divide the screen to two?
By maltesefalconese in forum EditingReplies: 4Last Post: 2nd May 2010, 19:54 -
Joining tracks?
By c5vetman in forum Authoring (DVD)Replies: 1Last Post: 19th Nov 2007, 15:18 -
Audio tracks
By Kelli Lancaster in forum EditingReplies: 0Last Post: 10th Oct 2007, 10:46
