Ok I had this working but I upgraded my TMPGE and DIVX codec. All my settings reset and I forgot how I fixed it. Iv'e searched the forums and can't seem to find the answer.
The problem is:
I am encoding from a 350meg AVI to MPEG. Unfortunatly it wants to make the output file 103% of a DVD.
As I want to put 3 of these AVI's onto one DVD it's a problem.
I should be able to make the file 33% of a DVD-R (about a 1.4gig MPEG) at about 3000 kbits/sec bitrate. I've done this many times before so I know it's no issue.
The thing is at the moment it's giving me no option, just the huge file at 103%. If I remember correctly it's something to do in the environmental settings, but for the life of me I can not work out what it is.
Results 1 to 16 of 16
Don't use the wizard and configure the bitrate manually. Use the DVDRhelp Bitrate Calculator to find the exact bitrate for your desired output size.
Originally Posted by teegee420
Excellent point. I'm sure you're right about the avi having VBR audio.
Hi cazna,
You might want to try my tool DIKO:
http://kvcd.net/forum/viewforum.php?f=79
It does DivX to DVD conversion in a completelly automated way, and can even burn the DVD with the movies in the end of the process. Just select your AVIs and come back later to get your already burned DVD. -
I'll look into the audio side of things now.
However
It may not be the very best way to do it, but I previously used the wizard and it all worked out good enough.
Just set it at whatever % I wanted and as long as I was happy with the bitrate it all worked.
As I am sure anybody reading this has felt, it just bugs me no end that I can't find the same solution again. -
All avi's are not created equal. You're going to run into problems from time to time no matter what.
I FOUND THE SOLUTION!!!!!!!!!!!!!!!!!!
Just to spread the joy around here it is.
If you go to "DivX decoder configeration utility" (this is part of the DivX codec)
Choose the "Quality settings" tab
Then UNTICK "Overlay extended mode"
Problem solved and it all works a treat.
I'm so happy I could burst -
That doesn't make a whole lot of sense, but whatever works. :P
Yup no sense at all, but it does work.
Thus I can use the wizard if I wish, and I dont have to do anything to the audio or use any calculators or anything.
I'm sure some killjoy will reply that by unticking that box it gives you cancer or something.
But for right here and now I'm tickled pink.
Thanks to everyone who took the time to offer their assistance and help. -
I'm not trying to jinx you or anything, but I'd be interested to know if your completed mpeg comes out ok. Please post again if all goes well.
So I guess the short version is ..... Yes, everything went well
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
Reformatted..now all output videos with XMediaRecode are too large
By smackyourfupa in forum Video ConversionReplies: 2Last Post: 25th Nov 2011, 16:34 -
Auto-GK file output, low quality despite large size
By Fallout1 in forum Newbie / General discussionsReplies: 10Last Post: 5th Oct 2009, 18:27 -
VirtualDub Output Too Large
By solarblast in forum EditingReplies: 2Last Post: 26th Dec 2007, 20:30 -
Mpeg too large to upload on youtube?
By nadizo in forum Video ConversionReplies: 2Last Post: 31st Oct 2007, 15:13
