I need a progarm that can cut avi files especially, divx/xvid files. Vdub crashes on me. What I need the program to do is allow me to specify the srat frame and end frame of the scene I want to cut, so it will cut exactly what I want. The program i am using right now: Media4PC
AVI Splitter works but does not allow me to cut by speciying frame, only by selecting cut points on a timeline.
All suggestions are appreciated, I'm, looking for something not overly expensive.
Thanks, Jonathan.
EDIT: That link doesn't work, but I downloaded AviUtl 0.98d from doom9.net and it comes with the english language file, however I cannot get the gui to display in english. Any suggestions?
teegee, tnaks for the suggestion, and I tried that program, but it reencodes the video, and I don't want to reencode the video at this point.
I'm thinking I'll just stick with AVI Splitter, since not every frame is a keyframe anyway.
Have you tried AviUtil editor - it works in frames and is very powerful.
download 0.97 here :>
http://ruriruri.zone.ne.jp/aviutl/
It's in Japanese! - don't worry here's the english patch to apply :>
http://arbor.ee.ntu.edu.tw/~jackei/enu097e.zip -
Sorry, but for me, Medi4PC AVI Splitter tells me that I must install the XVID Codec, which is already installed. Can anybody tell me howto work this out?
Thanx -
Better try to find out why VirtualDub crashes on you. And get a new version of the XviD codec, or try ffdshow.
/Mats
I need a free program that would convert my Dvds into XviD or Divx
By babeflover in forum DVD RippingReplies: 9Last Post: 22nd Apr 2012, 07:05 -
HELP Please - Best Program for DVD to DivX/Xvid to run on 64bit win7
By Jorocketoz in forum DVD RippingReplies: 7Last Post: 4th Feb 2010, 05:39 -
Best program to re-encode XviD files to make them smaller?
By Benhermies in forum Newbie / General discussionsReplies: 1Last Post: 24th Apr 2008, 22:32 -
What program gives the best quality results, when converting AVI/DIVX/XVID
By Rockstar452 in forum Authoring (DVD)Replies: 3Last Post: 3rd Dec 2007, 01:19 -
Can anyone recommend at good program for converting DVD to Divx or Xvid?
By gbgunner in forum DVD RippingReplies: 13Last Post: 10th Nov 2007, 17:18
