What programs on the Mac will allow me to author Mpeg 1 video files to DVD without converting them to Mpeg 2?
I believe you can do this with the latest version of Toast. If you add MPEG-1 video files to your DVD, they should not be recompressed. But, I think if you have MPEG-1 audio at the wrong rate then that will be reconverted to the 48kHz DVD rate and burned as PCM.
I use ffmpegX to do this.
It has a built in tool that will convert an mpeg, a folder full of mpegs or a .bin image and finish up with video_ts for burning
or
if you want to author the dvd in dvdsp or whatever,
demux the mpeg1;
Convert the audio to 48khz AC3
then you can build the dvd using the elementary m1v and ac3 files.
this is pretty cool because you can fit about 7 hours on 1 dvd.
good luck. -
Thanks for all the replys...
I have tried toast but I seem to have sync problems between the audio and video...These weren't in the original Mpeg files...
Would it help if I demuxed the Mpegs and converted the audio to 48khz instead of the standard 44.1khz of the originals remultiplexed and then added it to toast to be authored?
I have tested sizzle as well and it seems to work without the sync problems. The only issue with sizzle I have is that a simple navigation menu (like toasts) is not automatically constructed when you add titles.
Have many people tried playing an Mpeg 1 DVD on standard DVD players...I was just wondering if it would work on the majority of players (it works on mine but will it work on a friends).
Looking for a BD Authoring software that dont re-encode MPEG2 Files
By faramith in forum Authoring (Blu-ray)Replies: 11Last Post: 14th Dec 2011, 04:39 -
VCD/Mpeg1 to DVD/Mpeg2 - tools?
By shira in forum Video ConversionReplies: 5Last Post: 5th Jan 2011, 20:49 -
Conversion of MPEG2 files to smaller size
By tonyaldr in forum Video ConversionReplies: 13Last Post: 2nd Aug 2008, 21:43 -
Some DVD authoring programs will not accept CCE encoded mpeg2 files
By ettin in forum Authoring (DVD)Replies: 8Last Post: 18th Jun 2008, 14:57 -
mpeg1 to mpeg2 conversion picture quality will improve or the same?
By live4fun in forum Video ConversionReplies: 9Last Post: 9th Jul 2007, 08:27
