  1. well i finally figured out all my audio problems with xvid,ac3 and all that stuff and i though i was on my way to making a dvd. TMPGEnc says my mpg will be 3500Mb when its done converting my file, and it is 3500Mb. but when i go to burn the mpg with dvd builder from roxio it says the movie won't fit cause it needs 7500MB!!!!! what gives please help
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    Use a real authoring program like TMPGEnc DVD Author.
    Apr 2004
    It appears the program you are trying to use is wanting to re-encode the mpg file, at a much higher bitrate. You really should try a different authoring program.
    "Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so."
  4. thanks for the replys. i will try tmpgenc dvd author and go from there. thanks again!
  5. Member teegee420's Avatar
    Dec 2003
    Southern California
    Remember that there are guides on the download page if you get stuck.
