Guy I have a avi file that Divx5 codec and was going to make it into a vcd. What do you recommed in converting over to so there is little quality loss? The specs on the vid is 29.970 fps...... 512*352
Results 1 to 13 of 13
Convert it into a 352x240 (NTSC VCD) mpeg, use inverse telecine to change it to 23.976 fps.
"Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by ZippyP.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
I would imagine it's to avoid motion blurring if converted to 29.97. It's not like you can do 3:2 pulldown on mpeg-1, right(I think)?
Originally Posted by VCDHunter
On a side note, I've had avi's in the past that were 29.97 that should have been telecined, and when I tried running IVTC while converting to mpeg the result didn't look much better. -
I still don't know why the original avi would require IVTC
If you convert to 23.976 you get the equivalent of a 20% higher bitrate, more bits per frame. If your bitrate is high enough it won't make much difference but for VCD/SVCD it should be noticeable.
The bitrate increase was the only reason I would have done this. I just thought they may have been some secret that I wasn't aware of
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
Capture...convert...confused!!!
By cyber-junkie in forum Newbie / General discussionsReplies: 10Last Post: 15th Jan 2010, 13:11 -
Confused !!! I am trying to convert avi to dvd.
By reneewhite70 in forum Newbie / General discussionsReplies: 7Last Post: 2nd Apr 2009, 14:55 -
confused with mp4, won't play, can I convert?
By frankg in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2007, 07:18 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
