hello all,
whenever i convert PAL 25fps movies to PAL MPEG-2s using TMPGEnc Plus, the output quality is immaculate and i have no problems. however, the problems begin to arise when i process 29.971fps or 23.976fps NTSC movies using this program, unfortunately the output MPEG-2s are jittery and unsmooth. i read somewhere that when processing a 29fps NTSC movie, "3:2 pulldown" had to be selected? is this correct? also, when i introduce a 29fps NTSC movie into TMPGEnc to be converted, it automatically begins to process an "inverse telecine", which obviously does not help. which settings should i use when dealing with 23.976fps and 29.971fps NTSC movies? can anyone shed some light?
any help/suggestions/comments would be greatly appreciated, thanks.
Inverse telecine will go from 29 fps to 23 fps.
http://arbor.ee.ntu.edu.tw/~jackei/dvd2avi/ivtc/
The 3:2 pulldown goes from 23 fps to 29 fps
http://www.projectorpeople.com/tutorials/pulldown.asp
(How to) Inverse Telecine
By Cherbette in forum RestorationReplies: 16Last Post: 17th Nov 2011, 14:24 -
Inverse Telecine Anime (Death Note)
By Corpsecreate in forum Video ConversionReplies: 16Last Post: 7th Oct 2011, 03:55 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 16:34 -
PAL Inverse Telecine?
By Anakin in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 08:34 -
Inverse Telecine, IVTC
By kitty in forum GlossaryReplies: 1Last Post: 10th Jan 2008, 22:40
