I have been trying to set my system up so that I can use VirtualDub to do the post processing of some DV files, then frame serve to TMPGEnc to convert to MPEG 1.
I keep running into problems getting VirtualDub to recognise the DV files, which use the 'dvsd' codec. Either Raw files from capturing (using scenalyzer) or generated from Premiere.
What is the easiest way to get around this problem? I have tried installing the DV200/300 tools from pinnacle, but this then causes more problems for tools such as Windows Media Player.
My setup: Windows XP, 1,200MHZ Athlon, TMPGEnc2.01, VirtualDub 147.
Results 1 to 11 of 11
i installed the mainconcept dv codec, which let vdub read in the avi's. the only problem is, vdub will only accept type2 dv, type1 appears with no audio
Have tried the mainconcept one today and it fixes up all the problems. Problem with the water mark it leaves behind, but found it less of a problem if I frameserve from Virtual Dub to TMPGEnc. When I did this, it seemed to dissapear
Is the trial MC Codec still working after 5 Minutes. I always getting a black frame and/or no audio after 5 Min. of footage!
haven't tried a clip that long yet
I guess I will have to do that and see what happens.
Please try it. I gave up - even as I did get the official codec with my Hollywood Bridge - it didn't work (after 5 Minutes) with any Video program except MainConcept programs.
If you want a hazzle free codec, try the Adaptec Codec. I using that and it works perfectly. -
Just started a test now. Will take a while, but I'll get the results up.
Do you have alinke for downloading the DVSoft codec so I can try that out? -
Tested this and converted a 6:33 long clip, no sign of black screens or watermarks!
I use the MainConcept codec on a regular basis for 15-30 minute productions...never a problem or a hiccup. I used to use the Adaotec codec when I had a DPS SPARK card and I think the MC codec is higher quality. Besides, the DVSOFT won't work in W2k.
I don't know about Quality, bit DVSoft definitly works under Win2K. The Installation is of course a little bit cumbersome, but it really works!
Cannot get MTS files into virtualdub.
By jtl999 in forum Newbie / General discussionsReplies: 0Last Post: 28th Feb 2012, 21:41 -
Problem with MP4 files and VirtualDub on W7
By asterixvader in forum Newbie / General discussionsReplies: 0Last Post: 10th Dec 2010, 16:09 -
Output Files in VirtualDub
By Deter in forum EditingReplies: 9Last Post: 18th Jul 2010, 20:01 -
Joining AVI Files in VirtualDub.
By eliqush in forum EditingReplies: 12Last Post: 6th Jul 2009, 03:31 -
Error In Virtualdub Joining Two Like DV Files. Help?
By kpoman in forum EditingReplies: 2Last Post: 7th Jan 2009, 11:34
