Lately converting Xvids into a mpgfile with tmpenc give me a mpgfile that stutters, it looks like the framerate is totally different. However there is no problem with the audio
I installed the latest xvid codec.
What could be the problem?
Please help!
trenchy
Results 1 to 9 of 9
Could it be the field order? I've heard of that causing jerky playback.
LS -
It could be the result of a frame rate conversion, such as 23.976 to 29.97.
What are your source files NTSC or PAL and what are you encoding to NTSC or PAL ?
You can use GSpot to find out what the framerate of the original AVI file is, and compare that to the desired output framerate.
If you do need to convert between framerates, the guides can be found here:
https://www.videohelp.com/convert#4;41
Hope this helps,
Cobra -
I'm using kvcd templates to convert the xvids.
When I use a template with a resolution of 480x480 i get problems of stuttering.
When I use 352x480 I don't get this stuttering, anybody knows why?
I used to work with templates 480x480 without having any problems?
With the new avi files I have???
trenchy -
Make sure that the template uses film so that 2:3 pulldown is applied so that you dont get jerky encodes.
KVCD is mpeg-1, which I believe does not support 3:2 pulldown. You may have to use SKVCD.
Stuttering mpeg
By GerryJ in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 3rd Feb 2010, 20:23 -
Skipping - stuttering
By bryankendall in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Jan 2010, 11:55 -
TMPGEnc Xpress 4.0 stuttering conversion errors
By CasanovaFly in forum Video ConversionReplies: 2Last Post: 26th Nov 2009, 15:32 -
DVD stuttering
By Koron in forum Newbie / General discussionsReplies: 10Last Post: 5th Oct 2008, 14:16 -
stuttering video
By g0dm0de in forum DVD & Blu-ray WritersReplies: 6Last Post: 29th Jun 2007, 11:13
