I have been converting home wovies to wmv so that all of the relatives can view the movies via the web. I suppose i could take the time to reconvert to quicktime format but I was wndering if there is an app or method of enabling a Mac to view WMV.
Thanks in advance,
VC
Results 1 to 10 of 10
This is so much fun!
sure -- macs can view any type of wmv (including 9)
http://www.microsoft.com/windows/windowsmedia/software/Macintosh/osx/default.aspx"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Windows Media Player, VLC
They both play the format, WMP handles it better than VLC though -
MplayerX can also play certain wmv files. Altogether, you should be able to view pretty much any wmv.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
So can........... oh wait a min, i think all the apps avaliable have been covered. In short, YES it can play .wmv
So do most Macs have Windows media player installed? If not i'll have to convince my fatehr in law to install windows media player on his mac.
Thanks in advance,
VCThis is so much fun! -
They don't. You'll have to download and install it. You might also want to add VLC and MplayerX. Might add RealPlayer while you're at it.
Do PC's come with Apple Quicktime Player pre-installed? Just curious
Not any I've used...
All the ones I've seen it comes with the free version installed. But if they are custom built, then it's up to the builder to install.Originally Posted by galactica
hdr-cx115e live view: direct connection to tv or mac --> tv??
By paolocardelli in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 2nd Oct 2011, 18:27 -
How to view Windows Photostory WMV files on MacOS
By peerv in forum User guidesReplies: 0Last Post: 25th Jul 2011, 09:55 -
Lately, I can't view some wmv files
By videocheez in forum Software PlayingReplies: 6Last Post: 23rd Nov 2008, 18:54 -
How To View a Distorted WMV?
By Coolboy55 in forum Software PlayingReplies: 6Last Post: 10th Nov 2008, 10:18 -
How to view wmv.cfm files
By noles7 in forum Newbie / General discussionsReplies: 3Last Post: 7th Dec 2007, 12:21
