Results 1 to 10 of 10
  1. Have a mpeg file that I am going to covert to VCD, and I have converting a few before. This one when I try to use NERO and it starts to encode it, it says "error does not support this format". When I try to open in VIRTUAL DUB it says "error cannot detect file type" Why? What type of mpeg is this file. It plays perfect just cannot covert the darn thing. Also this is a 700mb file so it pretty much wise not to try to covert to SVCD seeing it would take until next week to finish.
    Dec 2002
    My Swamp
    AviCodec will give you information about mpeg files.
  3. I often find that splitting a video into a video and an audio stream then using these two separate works when using the original video fails.
    Martin.
  4. Thinks for info. Tried the avicodec and when I go to open the file Im getting same error mesage saying the excat same thing as with virtual dub.
    Dec 2002
    My Swamp
    If avicodec cant read the file then there is a problem with the file , it could be a header problem , you need an mpeg repair software , I haven't needed to find one yet. Have a look around the tools section. Unless someone can suggest one.
  6. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Restream is one you can use to fix stuff on MPEG files without re-encoding.
    capman21....are you using VirtualDubMod or just VirtualDub?
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
  7. Originally Posted by sacajaweeda
    I am using Virtual Dub 1.5.1 and just trying to open the file with it and keeps saying the same thing. Even tried TMPEG and same thing happens
  8. BAM!!!!! Got it guys!! Used a program called MPEG HEADER CORRECTOR. But what how did this fix this. If the header need to be repaired what does this mean?
    Dec 2002
    My Swamp
    Nice one - thanks for getting back to say how you got it going.
  10. guys try that software out if you need it. it took a 711 mb file and fixed it in under a min.
