Hi,
I don't understand something,
I just bought ads dvd xpress ,
then i started to capture analog video to my hard drive as .mpeg 2 for dvd.
ok. so i wanted to put on a dvd well, this is the time my problem started,
when i use ulead dvd movie factory to burn it on dvd it started to encode it to dvd format!
so, my point is why ads , canopus ,dazzle or whatever capture card company says (real- time encoding) i think they are lying!
because i also have old ati rage fury pro w/analog video input,
when i capture with it, i encode it also and without any freezing even if i capture 24hrs,
so, if somebody can lighten me up about this
what is the use if you have to re encode the files (and wait again) to put on dvd.
thank you .........................
Ulead DVD movie factory has a setting somewhere that says 'do not convert compliant video'. So if your source mpeg is DVD compliaqnt (correct res, bitrate etc) it will not re-encode. If it is NOT DVD complinat, you need to look at your capture settings to make sure they are.
You may be happy to hear that ADS is currently beta testing a new DTD, direct to disc, feature for capwiz update. Using this feature will be very nice for those of us that do not want to edit ofr fiddle with anything.
No release date has been given that I have seen, AFIK it is still in eary beta testing
link to forum specificly for ADS products
http://p211.ezboard.com/fpyro1394frm8
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 11th Jun 2011, 00:05 -
capture cards 360
By ihazcheezburga in forum Capturing and VCRReplies: 2Last Post: 19th Feb 2011, 20:14 -
What's new in capture cards for VHS capture?
By chowmein in forum Capturing and VCRReplies: 21Last Post: 29th Jul 2010, 09:03 -
Using 2 Hauppauge Capture Cards
By ddpool58 in forum Capturing and VCRReplies: 35Last Post: 21st Aug 2009, 22:53 -
Interferance on capture cards
By Signal in forum Capturing and VCRReplies: 35Last Post: 13th Sep 2007, 22:26
