ok just when i want to do something simple this has got to happen!
i was joining some movies together (the movies are 2 files, 700 megs each) with vdub using append avi , direct stream audio and video and save. some came out just fine, the audio video all that were flawless.
BUT
then on some i get this awfull full blown screech/PING kinda sound at the point of append and on some ocasions i also get the volume go down after that. the video seems fine just the audio does a whack job on me!
any way around this damn problem? i know i can hammer away at goldwave and get the right result but theres gotta be an easier solution. (as in some setting in virtualdub/nandub) anyone?![]()
.. kinda new that solution..
long way round.. just thought there was some kinda setting in vdub but oh well
thanx for the help anyway :P
Panasonic GS-250 taped race has area of no picture but sound
By helper in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Jul 2010, 04:32 -
Benq 1620 tray will not open? Just makes a click sound.
By Denvers Dawgs in forum ComputerReplies: 5Last Post: 23rd Jul 2009, 00:12 -
Weird horizontal line on top of the black area when playing movies(screen).
By Nitrius in forum Software PlayingReplies: 2Last Post: 23rd Aug 2008, 13:12 -
DVD movies Sound effects way loud voices... not so much.
By maxx409 in forum Newbie / General discussionsReplies: 7Last Post: 15th Feb 2008, 12:57 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 08:44
