anyone know what is the best codec pack i should use? or should I not use a codec pack all together? if i shouldnt use a codec pack, where would i get individual codecs that i need?
Results 1 to 10 of 10
There is no such thing as a good codec pack , get codecs as and when you need them you will find that you won't need many.
They can all be found in the tools section on the left under codecs.
If you have a file and it won't play , use GSpot or AVICodec to tell you what the codecs are that you need to play that particular file.
If you haven't got the codec it will tell you. If you have it will also tell you. -
try www.doom9.org.
You are going to get different answers. Some people use codec packs, some do not. I use the kazaa lite codec pack. I used to use nimo codec pack. If you are just going to be decoding, you might just need a couple of codecs. -
Codec packs are more trouble than there worth, download the codecs as and when you need them.
I'll second that! (Or third, or fourth or whatever...)Originally Posted by andyp1
/Mats -
I stay away from codec packs. d/l and install a codec if needed. No problems so far.
Never use a codec pack!!!!
"Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so." -
Yeh, don't touch em! It'll mess up your system as fast as a bishop running from a brothel raid!
To be fair, guys, some codec packs are better than others. The best in my opinion is K-lite Codec Pack. Always choose a custom install and only install what you need! If you're unsure about a particular codec, you probably don't need it.
True - but they're still all shitOriginally Posted by teegee420
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
What is the best Codec Pack?
By cim in forum Software PlayingReplies: 84Last Post: 8th Jul 2012, 12:45 -
Klite Codec Pack
By pepegot1 in forum EditingReplies: 6Last Post: 2nd Feb 2012, 22:39 -
Klite Codec Pack
By pepegot1 in forum EditingReplies: 1Last Post: 27th Jan 2012, 14:44 -
K lite codec pack
By Pumkinhead in forum Newbie / General discussionsReplies: 14Last Post: 26th Oct 2010, 14:12 -
Codec Pack selection?
By therock003 in forum Newbie / General discussionsReplies: 4Last Post: 21st Oct 2007, 11:50
