Results 61 to 67 of 67
My P4 2.8C @ 3.2 overclock with a stock Intel cooler runs @ 36C at full load with 2 panaflo 28cfm case fans.Originally Posted by johns0
The only way to compare AMD vs P4 is from a benchmark using the same software you intend to use.
AMD tends to have more raw CPU power for the buck.
Video transcoder/encoders are often optimized to Intel's MMC/SSE2/hyperthreading that tips advantage to Intel for those specific application areas (e.g. long encoding or effects rendering tasks).
Sometimes AMD wins sometimes P4 wins when normalized for cost.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Originally Posted by swiego
I've seen where having separate HDD for OS, capture file to RAM and RAM to TMP file can speed renders. This is mostly limited by disk controller contention and disk access times. CPU power still dominantes. The HDD/RAM system just needs to feed the CPU efficientlyRecommends: Kiva.org - Loans that change lives.
Surely this has minimal effect - most disk systems (barring floppy) will write faster than a CPU can kick out a video file.Originally Posted by swiego
That said, I have noticed a slight increase in speed if the source and target drives are on separate controllers.Regards,
Rob -
Sorry, I should have clarified, I didn't mean I/O throughput, I meant I/O efficiency.
It's a foregone conclusion that high I/O can burn CPU clock cycles, and some storage technologies are more CPU-efficient than others. -
You guys forget that bus speeds and cache come into play. Intel's do run hotter, I have a 3.2 Prescott and it runs hella hot. I also have a AMD Barton 3200XP that runs a little cooler. But back to the bus speeds and cache, Intel chips offer larger cache capacity and front side bus speeds than AMD. Basically a bottle neck after the CPU converts the data.
Config new PC - importance of CPU speed, L3 cache, RAM?
By OldAmateur in forum ComputerReplies: 19Last Post: 29th Jan 2010, 14:47 -
RAM and Video Card
By beavereater in forum ComputerReplies: 6Last Post: 11th Oct 2008, 14:23 -
Knowledgeable on the matter of CPU performance and encoding?
By Alendri in forum ComputerReplies: 8Last Post: 21st Sep 2007, 20:13 -
Matching CPU/Motherboard FSB to RAM Speed?
By rkr1958 in forum ComputerReplies: 2Last Post: 24th Jul 2007, 22:25 -
converting a ram (real video) file to mpeg problem
By Bamahusker in forum DVD RippingReplies: 3Last Post: 4th Jun 2007, 22:35
