my cousin's P4 3.0, 1GB(dd-r 3000ram), Radeon 9800Pro 128mb. He use TMPGEnc 2.5 to convert a 45min rmvb file to mpg and only took 25min..
my PC, Athlon 1700XP, 512sd-ram, Radeon 8500 64mb, converting the same file and took up 1hour..
I wonder which most important? CPU or video card or Ram?
Ram << i think 512 is enough or do you think more is good??
CPU << faster is mean convert faster
Results 1 to 30 of 67
CPU is faster that's why the conversion didn't take long to do.
Most important factor would defenetly be the CPU and then the RAM, the rest won't be an advantage to encoding unless you encode faster then a HDD can work which I doubt it
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
how about the quality? if i convert in my cousin's pc with radeon 9800pro VS my Radeon 8500. Does his quality better than mine?
The screencard is not involved in the converting process. Your pc will give just as good quality encodings as his even if you had the worst screencard in the universe.
I'd personaly go for an Athlon XP or Athlon 64, both are still cheaper then just abouy any Intel CPU and give better bang for the buck.
Best Regards,
Sefy Levy,
Originally Posted by SefyWant my help? Ask here! (not via PM!)
Dream on Johnny!
I've seen my PC beat a much faster Intel CPU using same programs! :P
Intel Fans only think it's an illusion their CPU is faster, maybe under the most optimized and specific conditions, but not on a daily regular user home PC it isn't!Email me for faster replies!
Best Regards,
Sefy Levy,
The reason why intels are faster is the higher clock frequency, at same amount of Mhz AMD is better. I agree with Sefy; More bang for the bucks. Its only individual preferences, both are good CPUs, as long as the model name doesnt end with RON.
I Loved the part about the "RON" thingy
I Haven't noticed it before, but celeRON and duRONEmail me for faster replies!
Best Regards,
Sefy Levy,
My youngest brother was the one who made me aware if it, he got a Duron 1.4, and said something like "Why does all the shit end with RON?". In other words, he wasnt impressed with the performance
I have a Pentium III 933. A 4 minute music video takes 1/2 hour. :P
On my old Duron 800 it took me less then your Pentium 3
Best Regards,
Sefy Levy,
Now now, 3 of my good friends go like Ron, Doron and Aaron
Best Regards,
Sefy Levy,
guess that explains what happened to enron...
In benchmarks alone, the P4 is better than AMD for video, but i'm sure if you could do a price-performance graph AMD would win. -
@flaninacupboard, that's not an "accurate" statement, as in a LOT of benchs i've seen, AMD beats Intel in many categories. Also, like i've said before, in a real life state where the system isn't OPTIMIZED for a specific CPU and does not use specific settings, or should we basicly say a REGULAR home user, i've seen my pathetic XP2000+ beat a P4 at 2600! in encoding and general usage.
I Don't believe benches cause they are always optimized for that latest CPU which just came out to make it look goodEmail me for faster replies!
Best Regards,
Sefy Levy,
all right then, i'll re-iterate.
as long as it's not set up in a retarded way, a P4 should beat an athlon at video encoding simply because of higher clock speed. processing a 32bit instruction 3,000,000,000 times a second is going to be quicker than 2,000,000,000 times a second. 11.1 GB/s versus 7.45GB/s. ok, that's a gross oversimplification, but you see where i'm going. -
Not really, if you put a 2000 AMD vs a 2000 Intel, in most cases AMD beats it
If you wanna compare 2000 AMD vs a 3000 Intel, then sorry, that's not realy a comparison.
Why not take a 3000 AMD vs a 2000 Intel and then see who wins
What i'm saying is, if you take Clock per Clock in speed, AMD will beat in a lot of the cases any Intel system.Email me for faster replies!
Best Regards,
Sefy Levy,
im stuck in 4 minds over getting a barton xp3200 athlon 64 or pentium 4 3.0/3.2
last 2 pcs iv had were athlons xp1700 and xp2600
xp1700 was a major improvement on its predecessor old pentiium 3
and the xp2600 is a fair bit faster than the xp1700
am very tempted to try a pentium 4 this time as video and audio processing will be the main tasks
any one have any ideas on a program which i can use to benchmark my pcs for video and audio editing other than just their relative times at ripping a dvd to xvid -
Personaly i'd go for an Athlon 64 since it's 64bit and gives you more headroom to grow, unfortunatly AMD started using Intel's tactics, and it has it's own socket version, so it won't fit on current XP boards
But if you plan on going a whole system, i'd recommand the Athlon 64 as in a LOT of benchs even the 1800 beat the crap out of P4 at 3000!Email me for faster replies!
Best Regards,
Sefy Levy,
Originally Posted by flaninacupboard
The internal architechture of modern microprocessor chips makes comparisons difficult and using ONLY clock speed makes the comparison invalid.
If you look at generalized benchmarks that don't intentionally favor INTEL or AMD, you'll see that AMD gets equivalent results with a much lower clock speed. -
You neglected to mention that AMD makes a much better room heater.
For the same program processing the AMD can run as hot as 160-170 degrees if not hotter (75-80c) .. the P4's will run in the 100 (40-45c) degree range. -
Originally Posted by DVD_Ripper
@DVD_Ripper, i'm with MpegEncoder, I don't know where you get your numbers from, but at that speed, it would burn! i'm in Israel and it's a hot country here, not to mention I have high humidity cause i'm living next to an ocean, and I have YET to get higher then 57c on the hottest day!
And I don't even have a Specialist Super-Fan! just a regular simple one!Email me for faster replies!
Best Regards,
Sefy Levy,
mpegencoder, i'm well aware that per clock the amd chips do more work, this is the whole basis for their model numbers rather than just clock speeds. all i am saying is that a 3000+ against a P4 3.0, the P4 would be faster at video encoding, simply because it crunches more numbers and that's all an mpeg encoder needs to do. i understand full well a 3Ghz athlon would be much faster than a 3Ghz P4, and when one arrives i'll gladly buy one. it's not an option yet though.
Facts show the opposite, AMD at lower clock speeds, not only match but also surpass Intel at higher Clock Speeds, BECAUSE of how their CPU works! they don't need a 3.0ghz to beat Intel's 3.0ghz, they already do it on 2.2ghz CPU's
Best Regards,
Sefy Levy,
Config new PC - importance of CPU speed, L3 cache, RAM?
By OldAmateur in forum ComputerReplies: 19Last Post: 29th Jan 2010, 13:47 -
RAM and Video Card
By beavereater in forum ComputerReplies: 6Last Post: 11th Oct 2008, 13:23 -
Knowledgeable on the matter of CPU performance and encoding?
By Alendri in forum ComputerReplies: 8Last Post: 21st Sep 2007, 19:13 -
Matching CPU/Motherboard FSB to RAM Speed?
By rkr1958 in forum ComputerReplies: 2Last Post: 24th Jul 2007, 21:25 -
converting a ram (real video) file to mpeg problem
By Bamahusker in forum DVD RippingReplies: 3Last Post: 4th Jun 2007, 21:35
