I am trying to copy mission to mars, but when i use dvdbackup, when i go to select the dvd, it won't allow me. And then when i try to click on the dvd on the desktop, it says that mac osx using it so it cannot be accessed. I have made tons of copies before, but this has never happened. Is there any way around this?
Try dragging the DVD to DVDBackup's window. Or, you can try using MacTheRipper, after you've quitted DVDBackup. Also, make sure DVD Player isn't playing the DVD while you try to rip it.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
before doing the VPC/DVDShrink method mentioned, i would exhaust all the Mac rippers first
MacTheRipper
YadeX
OSeX
if you get the same problems with all of these, one could say you probably will with the VPC/DVDShrink as well
make sure your disk is clean and fingerprint free that can cause problems also. Use some soap and warm water and acutally wash the disk off and let it dry with air, then use a lint free cloth to wipe away water marks if any are present -
If a disk is dirty best thing to use is a Disc DR. Or Game DR. It goes by many name's. They sell them at Best Buy and EB and FYE.
Weird problem with homemade DVD
By euroboy in forum Authoring (DVD)Replies: 12Last Post: 31st May 2011, 18:49 -
AVI on DVD/DivX- player, weird problem
By baranjac123 in forum Newbie / General discussionsReplies: 19Last Post: 23rd Mar 2011, 10:55 -
Weird, very weird thing demuxing a DVD
By jairovital in forum EditingReplies: 17Last Post: 22nd Oct 2010, 18:31 -
Ripped dvd conversion to xvid/divx weird audio problem
By victoriabears in forum Video ConversionReplies: 1Last Post: 12th Feb 2009, 13:41 -
TMPGEnc DVD Author 1.5 Problem... Only with these files... Weird, Help!
By acid_burn in forum Authoring (DVD)Replies: 3Last Post: 11th Jun 2008, 12:50
