how cna i extract audio from a mpeg file and clean up the background hissing? It is a programme i have capture through my TV card but the audio is really bad
Can someone help?
demux the file into .m2v (video stream) and .mp2 (audio stream) files.
convert the .mp2 (if necessary) to a format your audio editing software can recognize.
clean up the audio.
convert back to .mp2 (if necessary).
remux the new audio stream with the original video stream.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
ok what u just said meant absolutely nothing to me. How do i do...um....all that stuff u mentioned.....
Sorry...I just have to chuckle at your response!
No, I'm from Iowa. I only work in outer space. -
Originally Posted by angel129116
"demux" and "remux" are short for "demultiplexing" and "remultiplexing", respectively - multiplexing being the union of multiple streams (ie. audio and video).
personally, I would use TMPGenc to demux the .mpg file (File-> Mpeg Tools -> Simple Demux).
I'm not sure which audio editors will handle an .mp2 file, so a conversion might be in order. I think BeSweet can convert .mp2 <-> .wav
I'd use Wavelab for removing noise, since that's my audio editor of choice.
then using BeSweet for any reconversion, and TMPG's Mpeg Tools to remux the new audio with the old video.
Again - the Glossary and the Guides are your friend.- housepig
Housepig Records
out now:
Easy cheesy way to do it but it requires Adobe Audition and TMPGEnc DVD Author and the ac3 plugin.
1) Open Adobe Audition and choose "get audio from video" or something like that. Pick the video and it will extract the audio from it. edit it and save it as a .wav 16-bit 48khz.
2) Author the dvd using TMPGEnc DVD Author..replace the sound track of the original mpeg movie with the cleaned up one. Tell the track to re-encode audio to ac3.
BAM@!!
If you're wanting to leave it as an mpeg then loose the TMPGEnc DVD Author and replace it with Womble MPEG Video Editor. After step 1 open womble and mute the main video track then add the cleaned up one to the music track. Re-Encode and...
BAM@!!
dlv
Tools Needed Clean up iPhone Concert Video's Audio
By xr280xr in forum Newbie / General discussionsReplies: 5Last Post: 17th May 2011, 17:55 -
Extract Audio off a game CD
By ranchhand in forum AudioReplies: 9Last Post: 30th Mar 2011, 09:22 -
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 23rd Jan 2011, 23:28 -
.flv demux for audio clean up
By longislandgrafix in forum EditingReplies: 1Last Post: 29th Jan 2009, 10:17 -
Clean up audio on AVI file
By marybutts in forum AudioReplies: 2Last Post: 11th Jan 2008, 06:15
