I am capturing some clip in AVI format using Adobe Premiere Capture option from my analog camcorder through ADVC 100. My aim is to edit those clip in premiere and export it to an avi file for further conversion. After capturing, when I just drag the avi file to timeline and preview it, I am experiancing audio sync problem. But if I run the original avi file with real player it doesn't show up this issue. So I am guessing my capture is OK.
If I just export the movie without editing then also the problem remains the same. Am I missing some steps in premiere?
Check the video timeline where you drag your video/audio. If there is a little red triangle icon on one of the video tracks, then Premiere is telling you that your audio is not synced with its video track. If Premiere doesn't do this, then you might have dropped frames during capture.
-mojo-
http://mpmediaproductions.tripod.com (old site with stuff)
http://www.mpmediaproductions.com (official site, being designed)
http://www.paulinasdesigns.com (current project)
Adobe Premiere Elements 7 DVD Creation Quality Issue
By robvs in forum EditingReplies: 32Last Post: 20th Nov 2013, 10:07 -
adobe premiere CS5 video exporting issue
By bteamstephen in forum Capturing and VCRReplies: 4Last Post: 11th Dec 2010, 00:55 -
Canon XHA1 24f capture on Premiere CS4: sync issue
By dmyers in forum Newbie / General discussionsReplies: 3Last Post: 13th Jan 2010, 22:26 -
Adobe Premier Elements 4 audio issue
By Dark Alpha in forum EditingReplies: 0Last Post: 26th Jan 2008, 16:02 -
no audio in adobe premiere cs3
By vin4evr in forum Authoring (DVD)Replies: 1Last Post: 22nd Dec 2007, 12:28
