I know that when you tape a TV program that the close captioning works when you view the tape, how can you.. or should I say, can you get CC to work on a VCD or DVD?
let me revise... I have some old tv programs on tape that has close captioning and would like the CC to be on the VCD or DVD... can that be done?
Maybe I'm missing something, but why don't you use the subtitles?
Closed Captioning is not captured during video capture. Normally, only professional DVD authoring software (Scenarist, DVDMaestro, DVDStudioPro) allows adding CC to a DVD. This site is a great source of information about capturing and processing of CC for DVD purposes. It also has a tool to mux CC into m2v stream, which you can then remux back into the DVD.
The only minor nuisance is that so far I wasn’t able to capture video and CC at the same time with my Radeon 7200 VIVO. It returns an error about the resource conflict, so I have to run the tape twice – once capturing video, another time CC.
Supposedly, you can add CC to a VCD as well, but apparently no one has ever done this.
Another alternative is to buy an external CC decoder (about $100 if you can find one) and capture the video through it. This will burn the CC permanently into the picture.
It’s a pity that many people don’t even know what CC is or confuse it with subtitles. PAL guys need not worry though – this is purely an NTSC thing. -
Are there any other softwares besides Scenarist, DVDMaestro, and DVDStudioPro. I don't have a mac, Scenarist requires some crazy HP computer and PCI decoder card, and I can't find DVDMaestro; do they still exists?
DVD Maestro isn't produced anymore, but can be picked up secondhand from eBay and the likes.
Read my blog here.
Thx guns1inger, does DVD Maestro require any special decoder cards or cpu's?
Dimmer is incorrect. DVD recorders and PVRs OFTEN capture CC along with the video. It is embedded as additional user-meta-data in the multiplexed mpeg, and/or retained as picture signal in the non-visible area of the screen (line 21). It can also be captured using a number of PC capture cards (ATI notably). DV converter boxes (like Canopus's) should do a similar function.
Using MacPoodle's CC tools, one can extract, import, generate, and convert to and from a number of formats, including going from CC to standard subtitles.
I know, I've successfully done this.
If all you want to do is capture/digitize your VHS tape to a digital file or disc that includes CC info (enough to be decoded), your best bet would be a DVD recorder.
Scott -
i just did this this week in fact -- extracted the CC files off a tape (scc files) , converted them to srt files and hard burned them to a movie with v-dub and txtsub ...
SCC Tools is a wealth of info on the subject with great tools ..
http://www.geocities.com/mcpoodle43/SCC_TOOLS/"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Can rolling closed captioning be used as subtitles?
By jeanpave in forum SubtitleReplies: 4Last Post: 11th Jun 2010, 12:58 -
Closed Captioning in Europe
By Headway in forum DVD & Blu-ray PlayersReplies: 12Last Post: 5th May 2010, 09:10 -
no vhs closed captioning
By marvinwc in forum Newbie / General discussionsReplies: 8Last Post: 16th Oct 2009, 18:32 -
I am stuck with closed captioning/subtitles?
By Rjupiter in forum DVD RippingReplies: 7Last Post: 3rd Aug 2008, 15:21 -
closed captioning problem
By jeffreyslike in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Oct 2007, 11:09
