Hi there
I have a DivX (720x400px) that I wanna convert to DVD.
The problem that I get is that the mpg produced is a bit vertically streched. I chose 352x480 with keep ratio checked.
In TMPGEnc this is no problem because I choose Video Arrange Method Full Screen (Keep aspect ratio 2) and the image is the same as the DivX. TMPGEnc adds black on top and bottom to make it display on a 4:3 TV set.
I don't understand why MC would stretch the height of the video and not keep aspect ratio.
I like MC cuz it doesn't crush like TMPGEnc and it's a lot faster on 2 pass VBR.
Anyone know why this happens??
If the software player that you play the MPEG with doesn't understand MPEG aspect ratio's, then the playback will appear 'tall'. Does the video appear tall when it's played back on your standalone DVD Player?
Impossible to see the future is. The Dark Side clouds everything... -
I had the same problem but the source was 2.11:1 rather than 16:9.
You have to manually work out how of a border you'll need and set it up.
Personally I couldn't be bothered when TMPEnc did it without a problem.
16:9 -> 16:9 works well though. -
Just do the math.
850 / 2.11 = 400 vertical (rounded to nearest 8)
Resize to 720x400.
Add 40 pixel top letterbox, and 40 pixel bottom letterbox to fill out to 480 vertical and encode.Impossible to see the future is. The Dark Side clouds everything... -
Where did the 850 come from in your calculations
Sorry if I'm being a bit thick today -
DVD MPEG supports two aspect ratios. 16:9 and 4:3.
Convert those ratios to decimal:
16 / 9 = 1.77
4 / 3 = 1.333
Next, you take the vertical hight for your video, and multiply it times the aspect ratio of the display it is intended for (in this case 1.77, since your video is widescreen)
1.77 * 480 = 850 (rounded to nearest even)
( A 4:3 television would stretch it out to 640 pixels in width: 480x1.333 )
850 pixels is the full width that a DVD mpeg is stretched out to on playback.
Here's the long version: https://www.videohelp.com/forum/viewtopic.php?t=174200Impossible to see the future is. The Dark Side clouds everything...
How to convert squashed DVD aspect ratio back to normal??
By EricBalir in forum Video ConversionReplies: 5Last Post: 9th Sep 2011, 22:36 -
Trying to convert .mov to .flv - aspect ratio problems
By Graeck in forum ffmpegX general discussionReplies: 12Last Post: 21st Oct 2010, 17:55 -
MiniDV to DVD to .wmv Aspect Ratio Playback Problems
By 2therock in forum Video ConversionReplies: 15Last Post: 12th Jul 2010, 12:17 -
DVD to Quicktime .mov / Aspect Ratio Problems with DVDxDVPro
By accumulator in forum MacReplies: 3Last Post: 22nd Sep 2008, 06:45
