Hello, I have another Q for the great forum. I was just told about V.dub and that it can take your .avi file and compress it even smaller to where you can fit it on one cd. The problem is that when I try to use it, it says it can't connect to a capture driver. Any ideas or does this program even do what this guy told me it would do.
Thanks.
Results 1 to 1 of 1
Virtualdub 32bits error: cannot connect to the desired capture driver!
By Cauptain in forum Capturing and VCRReplies: 3Last Post: 21st May 2011, 11:17 -
how to connect an old camcorder to USB capture device
By deanno in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Dec 2009, 13:40 -
capture with twain driver
By zalves in forum Capturing and VCRReplies: 4Last Post: 27th Mar 2009, 14:46 -
How do i connect audio on capture card?
By GLE3 in forum AudioReplies: 11Last Post: 9th Mar 2009, 22:06 -
A tricky Driver for Capture Device Needed
By Digiliz in forum Capturing and VCRReplies: 9Last Post: 8th Jul 2008, 11:26
