I recently bought Sony DRU-530A DVD+-RW/_-R/CD writer and installed it on the same PC which coexist with my LG CD Writer. The Sony DRU-530A is supposed to support not only DVD +-R/RW but also CD-R/RW.
I wanted to test the CD-R/RW feature on the Sony and started trying to use it to format my CD-RW disks first and then used it to make VCD home movie using Nero Ver 6.3. Randomly, I found that I could only successfully created 50% of it (4/8 VCD) works properly. I can't play the home movie on any of the VCD/DVD player for those failed.
When I tried to reformat the failed disks and it HANG the system. When I rebooted the PC and tried to reformat it again. It complainted the disk may be damaged. I then tried to use the CD-Writer to format it and have the same problem for those CD-RW disk failed.
Can someone please tell me is the Sony DVD writer damaging my CD-RW disks ? If not, what is happening to my CD-RW disks. They have not been used no more than 2-3 times.
Thanks in advance for any assistance.
Results 1 to 1 of 1
Cutting without damaging source.
By Stikke in forum EditingReplies: 8Last Post: 17th Aug 2011, 14:52 -
how to copy from DVD recorder to external disk or blue-ray writer?
By uwacm@gmx.de in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2011, 06:14 -
Help w/ replacing an audio track on a DVD (w/o damaging menus, subtitles)
By svenge in forum DVD RippingReplies: 5Last Post: 29th Jun 2008, 02:37 -
Recovery of formatted Hard disk Sony DVD Recorder
By sparky10000 in forum DVD & Blu-ray RecordersReplies: 10Last Post: 1st Mar 2008, 16:47 -
DVD Writer damaging media?
By Jo A in forum DVD & Blu-ray WritersReplies: 7Last Post: 3rd Jul 2007, 08:58
