Hello,
I have downloaded some movies from the internent and I am trying to copy them to VCD. I am tring to use TMPGEnc and I get an error message telling me that the file can not open or is not supported. Please advise on what I need to do.
Thaks in advance!
Regards,
Jamie -
If the files are .avi chances are they are DivX. Make sure you have thye DivX codecs installed.
www.divx.com/ -
I have installed the latest divix codex 4.02. Is there anything else that I need to do?
Thaks again.
Regards,
Jamie -
I've just installed the codec pack on my win2000 service pack to release and afterwards got a message saying that important files had been replaced which were needed to run windows, Had to insert my windows CD presumable to re-install the originals, why should this be and should I be concerned?
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 09:08
