hi, i have 4 avi's that i woudl like to convert into 1 dvd, how would i go about doing so ? i dont know the type of avi it is (xvid divx) not sure about the sound quality on it either, can someone direct me to one of the guides or tell me what to do?, thank you
Results 1 to 14 of 14
check out the green section on the left. there are plenty of guides for you. basically what you are going to do is convert all the files to dvd compliant mpeg2 files. then you use an authoring program to make the dvd files, and then use a burning prog to burncan someone direct me to one of the guides
i have a problem with my avi's, when i play them in windows media player, they seem to be off sync, the audio is quicker than the video, how would i fix this ?
help me ?
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick
i tried that tutorial, and the end mpeg still came out to be out of sync.
being honest, if you can afford to buy a DVD player that will handle DivX and xVid then I'd do that, and simply burn the AVI's as data, and let the DVD player handle themfor you
That way you can get about 5-6 movies per DVD
If you want to do it the hard way, then you need an encoder that can convert the AVI to MPEG1/2, and create the necessary files
Then you get the problems off audio synch going off track du eto crap recording of the audotrack, its a nightmare, you could devote an entire website just to video conversion
Most people use CCE or MCE, or if you have p,enty of time, TMPGenc Plus
Like previosuly mentioned, actually read the guides, the vast majority are very , very good and tell you exactly what problems you WILL encounter -
well, i followed that tutorial posted above to the letter, but when tmpg gets to the part where it says how big its going to be its like 275% bigger than a dvd, my avi is in in low res dvd ntsc, so i tried it that way, and i can make it 50% of a dvd, hopefully when im done with this the A/V sync will be fixed.
i agreeOriginally Posted by steptoe
just get a dvd player which handles xvid and divx
look in the dvd player list they are pretty cheap should be able to get one for £60-£100
it will be far easier than doing the conversions
from
it would appear your pretty new to thisi have a problem with my avi's, when i play them in windows media player, they seem to be off sync, the audio is quicker than the video, how would i fix this ?
and unless you have a lot of free time and patience then you wont get many results when you fiddle with videos
if you insist on watching films away from the pc then either link a tv out from your graphics card to the tv or get an xvid and divx compatible player[/quote] -
well i vacation startedand i have plenty of time to do anything, so i think i'll learn how to edit/sync avis
, by the way i tried to follow this article https://www.videohelp.com/forum/userguides/140540.php, but it didnt work it was still out of sync, i cant figure out what to do. I used virtual dub to extractthe audio in full processing mode, and then i used goldwave to up the hz rate, then i used ulead movie factory to make the test dvd, joining the m2v and the wav file, i dindt complete the task i used the preview video player in ulead to see if it was out of synch and it was. i cant figure out how to fix this.
ok i managed to fix the sync problems with a program called avi info.
DarkManX4lf, I had a problem similar to yours. Try to take a look at this topic, it solved my problem:
https://www.videohelp.com/forum/viewtopic.php?t=221845Best regards,
Joelson.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
