Using the ADC-320 with the supplied Gateway 802.11G card I've had two problems.
The first was solved with a full firmware upgrade - playing selections of mp3's - either by artist or album - would lock up the player and darken the screen at exaclty 19 minuts and 54 seconds.
The second problem still exists - when the player loses connectionwith the server/network, it never can re-establish. Once it starts searching for a reconnection, you're hosed. The controls no longer work and eventually the player will lock up. The only thing to do then is to manually reboot the player.
Am I the only one seeing this? Does it go away if I go wired?
Thanks,
Jim
Results 1 to 1 of 1
Kaspersky reports bugs in network connected Samsung TVs and BD players
By jman98 in forum Latest Video NewsReplies: 1Last Post: 24th Apr 2012, 15:38 -
VHS player connected to PC - all captured footage out of sync!
By kingmustard123 in forum Video Streaming DownloadingReplies: 2Last Post: 30th Jul 2011, 16:23 -
Recommend DVD Player for old Gateway computer
By WannaWatch in forum ComputerReplies: 1Last Post: 24th Aug 2010, 19:56 -
when WAN is connected to the router the network speed drops to half...?
By stars in forum ComputerReplies: 18Last Post: 19th Feb 2008, 12:44 -
Backup External USB Hard Drive connected to Dish Network DVR
By AuditSup in forum DVD & Blu-ray RecordersReplies: 5Last Post: 2nd Nov 2007, 11:15
