Hey guys, i got a dvd that has only DTS 5.1 sound. It only shows video in all my dvd players. There is no sound. It works fine on the computer, but I was wondering is there any way I can play it on the dvd player without reburning?
TIA,
chroniX
The DVD standard requires that either LPCM or AC3 audio be present on the disk. It can also have DTS, but not by itself. AFAIK if you only have DTS then it won't play on most players, especially ones that don't have a DTS decoder. If you really want the DTS then you should include the AC3 as well, which will make it compatible with most players. I don't think there's any way around it.
"Art is making something out of nothing and selling it." - Frank Zappa -
thanks for the quick response!
so why would people spready around a non-commercial free dvd in DTS 5.1 or whatever? I downloaded (its free, not piracy) and its 16x9 and DTS 5.1 audio (as it says in the description). Who will be able to play this? If I cant fix it without reburning, then how do i fix it with reburning? How would I convert the DTS 5.1 audio to the normal AC3/LCPM or whatever audio so it will be compatible with all players?
Thanks,
chroniX -
Originally Posted by chroniX
-Rip the elementary streams (M2V and DTS) to your hard disk.
-Convert the DTS to AC3 (there must be some program for that).
-Re-author and burn the M2V and AC3 back to DVD using your favourite authoring package.
Hope that helps a bit."Art is making something out of nothing and selling it." - Frank Zappa -
Where are you downloading this from ?
Just curious as to what it is. -
i dont understand why u cant play a DTS only stream disc...it seems to me like u would just need a DTS decoder.
I've personally backed up several DVDs with one DTS audio track only, and they all play fine in my Sony DVP-F21 standalone.
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
Are your DVD players/Receivers DTS compatible? I agree with NaturalZinc, I believe that a DTS decoder is the only requirement.
George Carlin
DTS sound from DVD
By night_flight in forum Authoring (DVD)Replies: 8Last Post: 11th Apr 2012, 18:59 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
Please Help? How to restore DTS sound on DVD
By amir3852 in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2011, 16:31 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10 -
My device DVD can not play DTS
By HoanAkido in forum AudioReplies: 0Last Post: 9th Jul 2008, 22:35
