Has anyone experienced upward moving vertical lines in your captures? That's what I am getting when capturing from any source (VHS, Digital cable, etc.). These are faint but noticeable if you look for them. I am using my MSI Nvidia geforce 3 with s-video input. I am thinking that maybe it's the fans either on my video card or from the cpu that may be causing the vertical lines but can't be sure. I have tried using different s-video cables (the best I have is a Monster 3 meter s-video cable that is well sheilded) but still the problem is there. If anyone has any suggestions for me to try to eliminate this problem, please let me know. Thanks.
HERRINGBONE NOISE ... that's what it's called. Filter your signal, look for filters at Radio Shack. I have a few things here, DC blocks, attentuators, powered amps, etc. This is a coax issue.
could you be a little more specific as to exactly which filter i should first try? i have been to the digitalFAQ site you mentioned and i am still a bit confused as to what to get for the 'herringbone noise' as you call it.Originally Posted by lordsmurf
i have dl'd and am going to try the DVD Decrypter and Womble MPEGVCR also. if i like those, i will probably give a donation. i do a lot of DVD recording on DVD+RWs and need to edit them.
thanks -
i forgot to mention on my last quote. i am perplexed as to why there are white lines when viewing TV and after recording when my satellite reception is exceptionally clear?Originally Posted by lordsmurf
Reducing/eliminating scan lines?
By Captain Satellite in forum Video ConversionReplies: 9Last Post: 23rd Nov 2011, 07:37 -
Black horizontal lines when capturing
By cyanure in forum Capturing and VCRReplies: 3Last Post: 14th Aug 2010, 09:09 -
Eliminating VHS flaws.
By FreddieP in forum Capturing and VCRReplies: 21Last Post: 21st Jul 2010, 19:33 -
Crazy, wavy black lines on capturing from jerky video (images&vids in p
By osteopants in forum Capturing and VCRReplies: 4Last Post: 11th Jan 2008, 12:25 -
Capturing from my DV camcorder: artefacts with straight lines (fuzzy)
By hydrocynus in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 14th May 2007, 20:56
