I have a DVD-R with a VOB file that is corrupted. It stops playing on my standalone and computer. I have tried to rip it to HDD but it stops half way through. I have tried DVD rescue, isobuster,Virtual Dub with no luck. Any bright ideas? Is there a program that can repair VOB's?
Thanks.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
if you cant even copy it to your hard drive -- your certainly not going to be able to fix it .
best bet to is to play it in a stand alone (if you can) and capture it .
(edit -- i notice you say it doesnt play in stand alone either -- pretty well SOL at ths point) ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
You could try creating an image with Alcohol 120% and set it to skip read errors. Expect it to take a long time. Once it's through you can mount the image and copy from there. You should also expect it to be very corrupted but you might be able to cut the bad parts out with Womble MPEG2 VCR.
Just a thought. The whole thing could be a total waste of time.
faulty DVD-R will not finalize
By joecass in forum DVD & Blu-ray RecordersReplies: 19Last Post: 10th Nov 2009, 18:51 -
Faulty tv?
By alintatoc in forum ComputerReplies: 7Last Post: 18th Apr 2009, 12:24 -
How to copya faulty playable dvd
By decl in forum Authoring (DVD)Replies: 7Last Post: 24th Mar 2009, 11:15 -
Faulty wmv3 (9) codec problem
By Darius_bd in forum Newbie / General discussionsReplies: 6Last Post: 26th Dec 2008, 17:30 -
DVI-HDMI: Faulty cables or??
By vanjo in forum DVB / IPTVReplies: 4Last Post: 10th Oct 2007, 20:06
