Can anyone tell me how's the video quality when convert a DVD to VCD format?
Results 1 to 13 of 13
Originally Posted by aarontan78
There's a lot of factors involved. A VCD will not look as good as a DVD due to the resolution. You might want to provide more specifics... -
A little less than VHS quality, if that means anything to you.
IMO, VCD quality depends on system, PAL is noticeable better than NTSC, around 20% higher vertical resolution, can be close to acceptable sometimes. NTSC got way too low resolution for VCD, PAL isnt exactly great either.
A lot also depends on what you're going to use for playback. I've seen the same disk get played back on some systems with about VHS quality and another system like a copy of a VHS!
thanks for the advice.
actually I want to buy a DVD recorder to record VHS tape.
however, sometimes I also want to convert the VHS recorded DVD to VCD format.
Pls advice -
"convert the VHS recorded DVD to VCD format":
VHS to DVD: you can put at least 4 to 6 hrs tape into one DVD-R/+R.
VHS to VCD: 2 hrs tape into one CD should be nice.
Originally Posted by vioxx
No way! VCD is almost 80 min on a 700 MB (80 min) CD. Lowering the bit rate will (besides making it a "XVCD" - an "out of specs" VCD) make it look really bad.
/Mats -
Originally Posted by RayH
Actually, I want to convert a vhs tape to DVD then convert back to VCD.
But I'm not sure the video quality after I have so much conversions. -
VHS to DVD: Negligable quality loss. DVD to VCD: Serious quality loss.
/Mats
How best to convert/get rid off VCD/DVD/HDVD9?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jun 2010, 00:17 -
How to convert E-Book in PDF Format to VCD or DVD
By permataharahap in forum Newbie / General discussionsReplies: 2Last Post: 29th Jul 2008, 00:00 -
Playing VCD on Computer or convert to DVD
By corumz in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2008, 05:35 -
Settings to convert WMV to VCD/DVD-playable format?
By pingosimon in forum ffmpegX general discussionReplies: 5Last Post: 16th Jul 2007, 17:53 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
