Hi,
I recently bought a Panasonic pv-gs200 camcorder that can store ASF video files in mpeg4 format. I was wondering if there were any free or cheap cutting programs out there that can cut mpeg4 files once I get them on my computer. I think the video uses h263 encoding and the audio is g726.
My first intuition was vdubmod but I didn't try it yet because I thought later versions of vdub didn't open ASF files.
And if you're going to suggest TMPEGenc, note that I have exhausted the trial and don't want to buy it if that matters.
--Shayne
ASF sux. Micrsofts asswipe video compression. I believe the old Virtual Dub 1.3 may work. Also try using avisynth to write a script using DirectShowSource (may works, never has for me however). Personally, I'd use TMPGenc to encode asf's to mpeg or aiv (does a nice job and can still do with expired trial of TMPGenc. 2.5XX). For unlimited MPEG-1 and MPEG-2 encoding from asf or anything, find and downalod TMPGEnc 12A Beta.
Does anyone know any tool to check if files 'mpeg-2' are faulty?
By sgbd in forum Video ConversionReplies: 8Last Post: 13th Sep 2010, 21:12 -
Cut and Merge MPEG-2 Files
By flash_49 in forum EditingReplies: 8Last Post: 12th Feb 2010, 10:03 -
exception when encoding h263 FLV files in JFLVTOOL
By icodeflex in forum Video Streaming DownloadingReplies: 1Last Post: 21st Oct 2008, 19:00 -
mpeg vs h263
By catdaddio6 in forum Video ConversionReplies: 9Last Post: 1st Sep 2008, 22:07 -
Conversion from asf files to avi or mpeg
By Jescal in forum Video ConversionReplies: 1Last Post: 23rd Jan 2008, 16:37
