I have an SVCD bin file which I put into SVCD2DVD and ripped to MPG and created DVD folders. All works fine with end product DVD files.
However the generated mpeg file and the convered "xxxx_DVD" file I cannot delete.
I have rebooted pc and ensured no video software/SVCD2DVD open. Error message says file "access denied" "make sure the disk is not full or write protected and the file is not currently in use"
Help... at this rate if I can't delete my disc will be full in no time!!!
Cheers
Paul
PS I have no probs deleting files in general. I am running xphome with >10gb of free space
kick up in safemode that will work. or check this link http://www.ircspy.com/guides.asp?mode=display&id=531
regards phil -
Bizzare. Can you try renaming the file? If so can you delete thereafter (or after a reboot?)
It is really strange...
I have now rebooted machine some 7 hours later and the files have now GONE!!!!
It would seem that having read philmein suggested link that windows was still trying to read the files??
Ahhh.. They have now gone at last... thanks to all for your suggestions..
Paul
Question how to delete files that won't delete
By jimdagys in forum ComputerReplies: 18Last Post: 9th Sep 2009, 13:09 -
How to delete ISO files?
By millyvanilly in forum Newbie / General discussionsReplies: 13Last Post: 26th Jan 2009, 15:00 -
cannot delete files in ConvertXtoDvd folder
By ladysox in forum Newbie / General discussionsReplies: 7Last Post: 4th Feb 2008, 10:51 -
bsplayer delete my files?
By ieh4f in forum ComputerReplies: 3Last Post: 23rd May 2007, 12:39 -
SVCD2DVD error on start up 'Application has generated an exception...'
By Turnstyle in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 16th May 2007, 03:53
