  1. Ok so yeah , i burn a dvd ... ( tried a few different media ) burns fine
    but when it comes to playing it back it gos insane in the last few chapters... all freezing and skipping ... real annoying
    any ideas ?
    win xp
    Lite-on ldw 851S ( dvd burner )
  2. Shite media. The further out you travel on the disc, the more likely the problem is to occur.
    What kind of media were you using? And how close to the limit were you burning?
  3. Every time that has happened to me it's been the media. The solution of course is to limit the burn file size to 4.2GB or less.
  4. well first i was using bulkpaq oranges....... rubbish
    then i got some data write yellow as i heard great reviews for the price...
    then i found out they have changed the way these discs are made . so maybe it is the media
    lol you guys have summed it up .... it is always when i use the full disc
    what media would you reccomend ?
    thanx for your help guys .. realy appreciated
    thanx
  5. I use Taiyo Yuden DVD-Rs and Maxell DVD-Rs that are Made in Japan. That's pretty much my mainstay, but they're kinda pricey.
    Don't worry, there are others who will give you plenty of input on this matter.
