I have a Soundblaster Extigy with an optical SPDIF output that is said to be dolby digital 5.1 compatable. And my DVDplayer/stereo reciever is the AMW-T365. This reciever has an optical in that is said to be 5.1 dolby digital compatable. Whenever I play sound through it, I get it in 2 channel PrologicII stereo. I called Soundblaster and they said to configure my reciever, and amw said that they dont know what to do because the reciever should auto-sense the input channels and be 5.1 but it isnt, and they told me to post in this forum because someone could help me. So if anyone knows of something that may help, i could use the info.
Sincerely
Ian
If your just playing standard 'sound', like an audio CD, then it will only come out as 2 channel stereo (assuming your 'sound' is stereo). About the only time you can expect to hear 5.1 sound, is when your playing a DVD with 5.1 audio, AND using software that will output 5.1 sound via the SPDIF output. WinDVD will do this, but I don't know if PowerDVD will.
Unless your audio is 5.1 audio, don't expect 5.1 output.
Regular system sounds, wav's, mp3's, etc, will just be plain old stereo.Impossible to see the future is. The Dark Side clouds everything... -
What about games? And souround sound test programs? Because whenever the sound is behind me i get nothing. It just stays on Prologic II.
Only if the game supports and outputs 5.1 sound, AND the game knows to output the audio via the SPDIF output, and not the standard outputs on the sound card. Check the game configuration, and it might also be worth a trip to the games website. Typiclly you'll find forums there as well, with people who have already done the same research that you are currently going through.
Good luck!
dvd player +dvix+usb with external 160GB external HD problem...
By spidermen in forum Newbie / General discussionsReplies: 14Last Post: 14th Oct 2008, 19:45 -
ffdshow SPDIF
By AuroEdge in forum Software PlayingReplies: 4Last Post: 3rd Jun 2008, 05:44 -
SPDIF cable for dvd drive
By Milardo in forum DVD & Blu-ray WritersReplies: 15Last Post: 22nd Feb 2008, 19:01 -
SPDIF questions
By Digiface in forum AudioReplies: 0Last Post: 12th Feb 2008, 10:40 -
spdif question
By mluiere in forum Software PlayingReplies: 3Last Post: 22nd Jan 2008, 13:30
